Battery current-peaks
Hello guys!
I want to learn more about the electronics we are working with. We are trying to create a few different garage-builds, and find it intriguing to mix the different BR batteries and thrusters. Wanting to follow developer’s recommendations, we have stumbled upon something interesting when it comes to batteries and power cables.
The cables usually inform about “maximum continuous current rating”, but I cannot seem to find “maximum burst current rating”. Is this usually not an issue?
Examples:
BR 4S 14,8V battery
BR battery power cable set
6x BR T200 thrusters
The thrusters can theoretically pull above 120Amps if all six run at max at once. The cables are only rated for 80A (continuous pull).
BR 4S 14,8V battery
BlueTrail Battery Cable with Cobalt Connectors
Thrusters still pull 120Amps (theoretical max), but this cable is only rated for 40Amps (cont.)??
BR 6S 25,2V battery
6x BR T500 thrusters
The thrusters can theoretically pull 261Amps (cont.). How will the power cables hold up to this?
I understand that these currents are extremely rare and only for bursts, but will they not affect the lifespan of the cables? What is the worst case scenario if we pull too high currents for too long? Overheating cables or ECS?
I’d love to hear more about this, not limited to my questions.
Hi @Erlingns95,
Definitions of “burst” can vary substantially, so it’s a difficult rating to provide in a meaningful capacity (not to mention the variable impact of the operating conditions).
This comment covers the main reasoning behind how we’ve sized power cables - in short “use the biggest thing we can fit through a penetrator, and assume standard ROV usage won’t overload it”. Worth noting that cable ratings are generally not made for use in water, which can cool the cables much more effectively than when they’re in air.
Overheating the battery, cables, and/or ESCs can all be problematic. In the worst case things can melt and/or burn, resulting in permanent damage to those components, and possibly also some of the components around them.
