Hi, I’m about to buy a Bar30 and i’m equiped with a dropix (Drotek)
What should I buy to make it perfectly compatible with the dropix please ?
I’ll only use it from 0 to 1,2 meter (but the Bar02 U is not compatible Arduno) will it work fine ? What precision please for that range of depth ?
The atmosphéric pressure has an impact on the mesurement. How do you manage ?
Thanks a lot for your advices. Sam
kklemens
(Kevin)
2
@Samathey So we haven’t tested a Dropix with ArduSub. Does it load and work fine otherwise?
You will probably want an I2C Splitter Board to connect the DF-13 connector to your board. I looks like you need some jumper wires in there too.
The accuracy is +/- 50mbar = .5m at best. So the sensor is accurate to .5m from the accepted pressure standard.
The Bar30 has a resolution of 0.2mbar (Page 3, Resolution RMS) =2.04mm. So the sensor can read up to 2mm in changes.
For the atmospheric pressure, there is a Calibrate Pressure option in QGC.
