Bar100 giving weird depth readings
Hi, I have been experiencing some weird readings from my bar100 during testing.
I can without problems connect to the pressure sensor and recieve information when requested. The issue is, that the depth readings that I am getting makes no sense. I keep getting negative values like -0.4m or somewhere around that value, although I have only tested in depths of 1-2m. I am still getting normal temperature readings, but that shouldn’t matter in this case (as I expect that the temperature sensor is independent of the pressure sensor). I should add, I am running it on an Arduino with a i2c level converter.
Do you guys have any idea if my sensor might be busted ? Or if it needs some sort of calibration?
Cheers
