Assistance with 4 thruster ROV Programming
Hey guys,
I have been working on programming my 4 T100 thrusters to control forward/reverse and vertical movement of my ROV. I think that my code in running along the correct direction so far but I am unsure if it is completely right. Would you mind giving me some pointers and advice on how to proceed if my code is incorrect? I am posting it below:
#include <Servo.h>
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
const int servoRight = 8; //initializing servo pins
const int servoLeft = 7;
const int servoUP = 6;
const int servoDOWN = 5;
void setup() {
Serial.begin(9600); //turn serial on
servo1.attach(8); //set servo1 pin 8
servo2.attach(7); //set servo2 pin 7
servo3.attach(6); //set servo3 pin 6
Servo4.attach(5); //set servo4 pin 5
// send “stop” signal to ESC.
servo1.writeMicroseconds(1500);
servo2.writeMicroseconds(1500);
servo3.writeMicroseconds(1500);
servo4.writeMicroseconds(1500);
delay(5000); // 5 sec delay to allow the ESC to //recognize the stopped signal
void loop() {
if (Serial.available()) {
// Turning Left, input of TL in serial monitor means Turn Left
char a = Serial.read(); //stores first value of the serial input as a character
char b = Serial.read(); //checks if same as necessary input
char c = Serial.read(); // for int values only
char d = Serial.read(); //for int values only
Serial.write(a);
Serial.write(b);
Serial.write(c);
Serial.write(d);
if (a == ‘T’) {
if (b == ‘L’) {
servo1.writeMicroseconds(1700); // then gives commands
Serial.write(“TL”);
// Turning Right
if (b == ‘R’) {
servo2.writeMicroseconds(1700);
Serial.write(“TR”);
// Forward and Reverse
else {
if (a == ‘1’) {
if (b == ‘5’) {
servo1.writeMicroseconds(1500); //don’t move
else if (b == ‘6’) {
servo1.writeMicroseconds(1600); //slow forward
servo2.writeMicroseconds(1600);
else if (b == ‘7’) {
servo1.writeMicroseconds(1700); //faster forward
else if (b == ‘4’) {
servo1.writeMicroseconds(1400); //slow reverse
servo2.writeMicroseconds(1400);
else if (b == ‘3’) {
servo1.writeMicroseconds(1300); //faster reverse
servo2.writeMicroseconds(1300);
// Up and Down (Vertical Movement)
else {
if (a == ‘1’) {
if (b == ‘5’) {
servo3.writeMicroseconds(1600);
servo4.writeMicroseconds(1600);
servo3.writeMicroseconds(1700);
servo4.writeMicroseconds(1700);
servo3.writeMicroseconds(1400);
servo4.writeMicroseconds(1400);
servo3.writeMicroseconds(1300);
servo4.writeMicroseconds(1300);
else {
servo1.writeMicroseconds(1600); // if no forward command
servo2.writeMicroseconds(1600); // then just go straight
servo3.writeMicroseconds(1500); // if no vertical command
servo4.writeMicroseconds(1500); // stay level
Vaughn,
Thanks for posting. I think your code will result in the thruster outputs you are looking for. I’d recommend looking into ways to use a joystick or similar control method as I think it’s going to be very difficult to control the ROV with typed commands!
Best,
Rusty
Hey Rusty!
Thanks for getting back to me so quickly. I thought the same thing as well but when I attempt to compile the code in the arduino command prompt I keep getting hit with the errors shown below:
sketch_apr02a:89: error: stray '' in program
sketch_apr02a:91: error: stray '' in program
sketch_apr02a:97: error: stray '' in program
sketch_apr02a:105: error: stray '' in program
sketch_apr02a:111: error: stray '' in program
sketch_apr02a:125: error: stray '' in program
sketch_apr02a:127: error: stray '' in program
sketch_apr02a:135: error: stray '' in program
sketch_apr02a:143: error: stray '' in program
sketch_apr02a:151: error: stray '' in program
sketch_apr02a:159: error: stray '' in program
sketch_apr02a:181: error: stray '' in program
sketch_apr02a:183: error: stray '' in program
sketch_apr02a:191: error: stray ‘' in program
sketch_apr02a:199: error: stray ‘' in program
sketch_apr02a:207: error: stray ‘' in program
sketch_apr02a:215: error: stray ‘' in program
sketch_apr02a.ino: In function ‘void setup()’:
sketch_apr02a:33: error: ‘Servo4’ was not declared in this scope
sketch_apr02a.ino: In function ‘void loop()’:
sketch_apr02a:89: error: ‘u2018T’ was not declared in this scope
sketch_apr02a:89: error: expected )' before 'u2019' sketch_apr02a:91: error: 'u2018L' was not declared in this scope sketch_apr02a:91: error: expected )’ before ‘u2019’
sketch_apr02a:97: error: ‘u201cTL’ was not declared in this scope
sketch_apr02a:105: error: ‘u2018R’ was not declared in this scope
sketch_apr02a:105: error: expected )' before 'u2019' sketch_apr02a:111: error: 'u201cTR' was not declared in this scope sketch_apr02a:125: error: 'u20181' was not declared in this scope sketch_apr02a:125: error: expected )’ before ‘u2019’
sketch_apr02a:127: error: ‘u20185’ was not declared in this scope
sketch_apr02a:127: error: expected )' before 'u2019' sketch_apr02a:135: error: 'u20186' was not declared in this scope sketch_apr02a:135: error: expected )’ before ‘u2019’
sketch_apr02a:143: error: ‘u20187’ was not declared in this scope
sketch_apr02a:143: error: expected )' before 'u2019' sketch_apr02a:151: error: 'u20184' was not declared in this scope sketch_apr02a:151: error: expected )’ before ‘u2019’
sketch_apr02a:159: error: ‘u20183’ was not declared in this scope
sketch_apr02a:159: error: expected )' before 'u2019' sketch_apr02a:181: error: 'a' was not declared in this scope sketch_apr02a:181: error: 'u20181' was not declared in this scope sketch_apr02a:181: error: expected )’ before ‘u2019’
sketch_apr02a:183: error: ‘b’ was not declared in this scope
sketch_apr02a:183: error: ‘u20185’ was not declared in this scope
sketch_apr02a:183: error: expected )' before 'u2019' sketch_apr02a:191: error: 'u20186' was not declared in this scope sketch_apr02a:191: error: expected )’ before ‘u2019’
sketch_apr02a:199: error: ‘u20187’ was not declared in this scope
sketch_apr02a:199: error: expected )' before 'u2019' sketch_apr02a:207: error: 'u20184' was not declared in this scope sketch_apr02a:207: error: expected )’ before ‘u2019’
sketch_apr02a:215: error: ‘u20183’ was not declared in this scope
sketch_apr02a:215: error: expected `)’ before ‘u2019’
sketch_apr02a.ino: At global scope:
sketch_apr02a:231: error: expected unqualified-id before ‘else’
sketch_apr02a:243: error: expected declaration before ‘}’ token
I’m not quite sure why I keep getting these "" errors when I have none in my program. What do you think could be causing this problem for me?
Hi Vaughn,
This is a tricky error! It’s cause by the fact that the quotes used around characters are special quotes (probably from copy and pasting from MS Word or similar).
This:
has different quotes than this:
else if (b == '7') {
The compiler doesn’t recognize the fancy formatting of the first version. Try replacing all of those and it should work.
Best,
Rusty
Rusty,
I greatly appreciate your help and advice, I am having one more problem I could use your guidance with though. I fixed the problem above thanks to your advice but when I try to compile and upload my code it keeps telling me that my variables (a, b, c, d) are not defined in the void loop() where I have the code Serial.write(a); and it tells me this for each of the variables being written to. If you could just give me some advice where I am going wrong I would very much appreciate it.
Thanks,
-Vaughn
Rusty,
So okay I diagnosed what the problem might be. I believe that in my ‘else’ statements that the arduino command prompt does not like the I am comparing a char to integer values such as I am listing below:
else {
if (a == ‘1’) {
if (b == ‘5’) {
What do you think I could do in order to solve this problem? Do you think that instead of comparing ‘a’ to ‘1’ it would be more prudent to use a hex value for ‘1’ and other other subsequent integers that I will be equating to my chars?
Thanks so much for your time and help,
-Vaughn
The problem is that your decision structure looks like this:
if(Turncommand) {
turncode
} else {
forwardcode
} else {
verticalcode
The compiler is expecting an if before the second else, the first else closes the if statement, you can’t have two else conditions.
try this:
if(Turncommand) {
turncode
} else if(Forwardcommand) {
forwardcode
} else if(Verticalcommand){
verticalcode
} else {
invalid command, do nothing (maybe stop motors because communications have gone screwy)
-Jacob
Jacob,
Thank you very much for replying to me. I took the advice that you gave me and implemented it into my code and it was finally able to compile. I really appreciate your time and I will be connecting all of our devices shortly to see if this code will work successfully for our design.
-Vaughn
