3 brushed motor rov code
I’m coding the motors for an ROV. We’re using 3 motors, each controlled by a 2 input H-bridge. I cant test the motors as I wont be in the workshop for while. I was just wandering if my code looks okay… It compiles but not sure if it will actually work.
// Left Motor
int enA = 9;    //PWM
int in1 = 8;
int in2 = 7;
// Right Motor
int enB = 10;   //PWM
int in3 = 5;
int in4 = 4;
// Vertical Motor
int enC = 11;   //PWM
int in5 = 13;
int in6 = 12;
// Joystick Input
int joy1Vert = A0; // Joystick 1 Vertical
int joy1Horz = A1; // Joystick 1 Horizontal
int joy2Horz = A2; // Joystick 2 Horizontal
// Motor Speed Values - Start at zero
int MotorSpeed1 = 0;
int MotorSpeed2 = 0;
int MotorSpeed3 = 0;
static const int Joy1Vert = 511; //Middle value for joysticks
static const int Joy1Horz = 511;
static const int Joy2Horz = 511;
void setup()
  // Set all the motor control pins to outputs
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(enC, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  pinMode(in5, OUTPUT);
  pinMode(in6, OUTPUT);
  // Start with motors disabled and direction forward
  // Motor A
  digitalWrite(enA, LOW);
  digitalWrite(in1, HIGH);
  digitalWrite(in2, LOW);
  // Motor B
  digitalWrite(enB, LOW);
  digitalWrite(in3, LOW);
  digitalWrite(in4, LOW);
  // Vertical Motor
  digitalWrite(enC, LOW);
  digitalWrite(in5, LOW);
  digitalWrite(in6, LOW);
void loop() {
  // Read the Joystick X and Y positions
  joy1Vert = analogRead(joy1Vert);
  joy1Horz = analogRead(joy1Horz);
  joy2Horz = analogRead(joy2Horz);
  if (joy1Vert < 460)
    // This is Backward
    // Set Left Motor backward
    digitalWrite(in1, LOW);
    // Set Right backward
    digitalWrite(in3, HIGH);
    digitalWrite(in4, LOW );
    //Determine Motor Speeds
    joy1Vert = joy1Vert - 460; // This produces a negative number
    joy1Vert = joy1Vert * -1;  // Make the number positive
    MotorSpeed1 = map(joy1Vert, 0, 460, 0, 255);
    MotorSpeed2 = map(joy1Vert, 0, 460, 0, 255);
  else if (joy1Vert > 564)
    // This is Forward
    // Set Left Motor Forward
    digitalWrite(in2, HIGH);
    // Set Right Motor forward
    digitalWrite(in3,LOW);
    digitalWrite(in4,LOW );
    MotorSpeed1 = map(joy1Vert, 564, 1023, 0, 255);
    MotorSpeed2 = map(joy1Vert, 564, 1023, 0, 255);
  else
    // Left & Right motors Stopped
    MotorSpeed1 = 0;
    MotorSpeed2 = 0;
  // Steering
  if (joy2Horz < 460)
    // Move Left
    // reverse readings
    joy2Horz = joy2Horz - 460; // This produces a negative number
    joy2Horz = joy2Horz * -1;  // Make the number positive
    // Map the number to a value of 255 maximum
    joy2Horz = map(joy2Horz, 0, 460, 0, 255);
    MotorSpeed1 = MotorSpeed1 - joy2Horz;
    MotorSpeed2 = MotorSpeed2 + joy2Horz;
    // Don't exceed range of 0-255
    if (MotorSpeed1 < 0)MotorSpeed1 = 0;
    if (MotorSpeed2 > 255)MotorSpeed2 = 300;
  else if (joy2Horz > 564)
    // Move Right
    joy2Horz = map(joy2Horz, 564, 1023, 0, 255);
    MotorSpeed1 = MotorSpeed1 + joy2Horz;
    MotorSpeed2 = MotorSpeed2 - joy2Horz;
    // Don't exceed range of 0-255 for motor speeds
    if (MotorSpeed1 > 255)MotorSpeed1 = 300;
    if (MotorSpeed2 < 0)MotorSpeed2 = 0;
  if (joy1Horz < 460)
    // This is Downwards
    // Set vertical motor downwards
    // As we are going backwards we need to reverse readings
    joy1Horz = joy1Horz - 460; // This produces a negative number
    joy1Horz = joy1Horz * -1;  // Make the number positive
    MotorSpeed3 = map(joy1Horz, 0, 460, 0, 255);
  else if (joy1Horz > 564)
    // This is Upwards
    digitalWrite(in5, HIGH);
    digitalWrite(in6, HIGH);
    MotorSpeed3 = map(joy1Horz, 564, 1023, 0, 255);
  else
    // This is Stopped
    MotorSpeed3 = 0;
  // prevent buzzing at very low speeds
  if (MotorSpeed1 < 8)MotorSpeed1 = 0;
  if (MotorSpeed2 < 8)MotorSpeed2 = 0;
  if (MotorSpeed3 < 8)MotorSpeed3 = 0;
  // Set the motor speeds
  analogWrite(enA, MotorSpeed1);
  analogWrite(enB, MotorSpeed2);
  analogWrite(enC, MotorSpeed3);
@soyboy97 how did it go?
