Any examples of controlling Ping360
I just start to use Ping 360 recently. I find that if I want to have arbitrary scanning sector I should use control protocol.
I understand that I need to write code to generate control command in ping-protocol based on documentation, however, it is hard for a beginner to start.
Specially, do you guys have any tutorial or examples code to control the sonar by code(not ping-viewer).
Thanks a lot for the help.
Hi @LixingHe, assuming you haven’t already got this sorted, the ping360.py file that gets generated when you install ping-python has an example at the bottom. Is there anything more that you want an example/reference for?
Thank you for your reply. As you mentioned, ping360.py does provide helpful example.
You can also check the ping-protocol documentation:
https://docs.bluerobotics.com/ping-protocol/pingmessage-ping360/
