We have had trouble with the T200 + Basic ESC knocking out multiple acoustic sensors on custom vehicles. Is there any other ESC that others have used with the T200 that we should try to mitigate this?
I assume that by “knocking out” you mean that the esc/motor is putting creating noise which is swamping the signals on your acoustic devices. If so, it is possible you might find a quieter ESC, but they’re all going to use PWM to modulate the motor power and that makes a lot of noise.
If you’d like to describe your system in more detail there may be some other mitigations I could suggest.
Hi @aspears, welcome to the forum ![]()
You may be interested in an ESC like the one discussed here, but I’d recommend trying to more precisely isolate the cause of the issue first, in case there are other simpler explanations and/or solutions. This post may be worth reading through as a starting point ![]()
