Adding voltage to bottom bar
sorry for that simple thing but I have hidden the light percent display in the bottom bar with a click on the trashcan and now I want to place instead the voltage of the battery. I looked everywhere but didn’t found how to create the voltage display or any other display in the bottom bar. Deleting is easy but creating is impossible for me at this moment. Any ideas for me?
Thanks a lot
Chris
Hi @schleitaucher -
You’ve not specified what program you’re using for your GCS!
It’s possible to add battery voltage in both Qground control and Cockpit- by default Cockpit shows this in the upper right.
For QGC, simply click the pencil icon, then add a row or column, and click the values that appear. For voltage select battery in the first drop down and voltage in the second. Documentation here
In Cockpit, go to menu, edit interface, select mini widget in the bottom left, and scroll to find the battery widget. You could also display just the voltage with the generic indicator widget. Documentation here.
Hi @tony-white
Thanks for the fast reply.The Dropdown in the bottom left and then drag and drop was the solution. Thanks!!
