If a SERVOn_FUNCTION parameter is set to Disabled (0) then its corresponding output should be controllable directly ![]()
For a standard servo-style PWM signal you should be able to use any of the outputs, but AUX 1/2/3 (Servo 9/10/11 on Navigator) are marginally easier with the currently available firmware[1], because of the existing servo_n_* joystick button functions.
That said, you can set custom functions in QGC if necessary, and more easily in Cockpit, so there are options available ![]()
There is some ongoing work to make the “servo” functions configurable to arbitrary motors, but it’s not yet merged/available ↩︎
