Hi @vrr20, welcome to the forum ![]()
I’ve moved your comment to its own post, because the thread you posted it in was specifically for the Pixhawk 4, which you do not have.
I’m a bit confused by this. The Pixhawk has an MC5611 barometer has part of its internal sensor suite, but that should appear in SCALED_PRESSURE - SCALED_PRESSURE2 is normally used for an external barometer (like our Bar30 (MS5837-30BA) or Bar100 (Keller 7LD-PA)).
Could you please clarify
- Are you running ArduSub on your Pixhawk (and if so, which version)?
- Do you have an external barometer? If so, is it actually using an MS5611 sensor, or something else?
- Are your sensors fully plugged in, and does the issue persist when you reboot your Pixhawk? In this similar post from a while ago the problem ended up resolving itself after similar checks.
