3D printed compression mounts for my AUV
These are some of the parts of a solar AUV that I have been working on. It may look a little abstract without the fairings, rudder, and propulsor, etc. mounted- but I wanted to share some of my progress.
These mounts are designed based on fluid compression fittings. The conical orange TPU pieces act as ferrules that wedge into the conical seats of the yellow mounts. A retainer will thread onto the yellow body and clamp the ferrules down, but the retainers aren’t shown here yet.
I designed the mounts this way because it allows them to slide along the parallel tubes that make up the backbone of the AUV, which makes it easy to adjust the center of mass and buoyancy. The compression fittings also eliminate the need for metal fasteners, which mitigates the potential for any possible corrosion with the carbon fiber.
Cool project @tylerssims!
If I’m understanding correctly you can (easily) slide the yellow mounts to the desired location, then clamp them into place with a retainer on each side that compresses the orange TPU pieces, which effectively creates a friction-fit mounting? Really neat idea, and the 3D printed nature of the mounts (and presumably also the TPU pieces?) would make this great for design iteration, and replacement of broken parts :slight_smile:
Thanks, yea, you got the right idea! The TPU pieces are printed with low infill so they are quite squishy.
