I’ve installed python 37-32 and copied mavproxy files from your fork in the same directory as the python.
I am running cmd in admin mode and go the the directory where python is install and run
C:\Users\Etienne\AppData\Local\Programs\Python\Python37-32>python setup.py build install
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_smartcamera\sc_vi
deo.py to sc_video.cpython-37.pyc
  File "build\bdist.win32\egg\MAVProxy\modules\mavproxy_smartcamera\sc_video.py"
, line 57
    print "failed to open camera, exiting!"
SyntaxError: Missing parentheses in call to 'print'. Did you mean print("failed
to open camera, exiting!")?
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_smartcamera\sc_we
bcam.py to sc_webcam.cpython-37.pyc
  File "build\bdist.win32\egg\MAVProxy\modules\mavproxy_smartcamera\sc_webcam.py
", line 43
    print "failed to open webcam %d" % self.instance
to open webcam %d" % self.instance)?
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_smartcamera\ssdp.
py to ssdp.cpython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_smartcamera\__ini
t__.py to __init__.cpython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_speech.py to mavp
roxy_speech.cpython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_terrain.py to mav
proxy_terrain.cpython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_test.py to mavpro
xy_test.cpython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_tracker.py to mav
proxy_tracker.cpython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_tuneopt.py to mav
proxy_tuneopt.cpython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\modules\mavproxy_wp.py to mavproxy
_wp.cpython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\modules\__init__.py to __init__.cp
ython-37.pyc
byte-compiling build\bdist.win32\egg\MAVProxy\__init__.py to __init__.cpython-37
.pyc
creating build\bdist.win32\egg\EGG-INFO
installing scripts to build\bdist.win32\egg\EGG-INFO\scripts
running install_scripts
creating build\bdist.win32\egg\EGG-INFO\scripts
copying build\scripts-3.7\MAVExplorer.py -> build\bdist.win32\egg\EGG-INFO\scrip
ts
copying build\scripts-3.7\mavflightview.py -> build\bdist.win32\egg\EGG-INFO\scr
ipts
copying build\scripts-3.7\mavproxy.py -> build\bdist.win32\egg\EGG-INFO\scripts
copying build\scripts-3.7\mp_slipmap.py -> build\bdist.win32\egg\EGG-INFO\script
s
copying build\scripts-3.7\mp_tile.py -> build\bdist.win32\egg\EGG-INFO\scripts
copying MAVProxy.egg-info\PKG-INFO -> build\bdist.win32\egg\EGG-INFO
copying MAVProxy.egg-info\SOURCES.txt -> build\bdist.win32\egg\EGG-INFO
copying MAVProxy.egg-info\dependency_links.txt -> build\bdist.win32\egg\EGG-INFO
copying MAVProxy.egg-info\requires.txt -> build\bdist.win32\egg\EGG-INFO
copying MAVProxy.egg-info\top_level.txt -> build\bdist.win32\egg\EGG-INFO
copying MAVProxy.egg-info\zip-safe -> build\bdist.win32\egg\EGG-INFO
creating 'dist\MAVProxy-1.6.1-py3.7.egg' and adding 'build\bdist.win32\egg' to i
t
removing 'build\bdist.win32\egg' (and everything under it)
Processing MAVProxy-1.6.1-py3.7.egg
Removing c:\users\etienne\appdata\local\programs\python\python37-32\lib\site-pac
kages\MAVProxy-1.6.1-py3.7.egg
Copying MAVProxy-1.6.1-py3.7.egg to c:\users\etienne\appdata\local\programs\pyth
on\python37-32\lib\site-packages
MAVProxy 1.6.1 is already the active version in easy-install.pth
Installing MAVExplorer.py script to C:\Users\Etienne\AppData\Local\Programs\Pyth
on\Python37-32\Scripts
Installing mavflightview.py script to C:\Users\Etienne\AppData\Local\Programs\Py
thon\Python37-32\Scripts
Installing mavproxy.py script to C:\Users\Etienne\AppData\Local\Programs\Python\
Python37-32\Scripts
Installing mp_slipmap.py script to C:\Users\Etienne\AppData\Local\Programs\Pytho
Installing mp_tile.py script to C:\Users\Etienne\AppData\Local\Programs\Python\P
ython37-32\Scripts
Installed c:\users\etienne\appdata\local\programs\python\python37-32\lib\site-pa
ckages\mavproxy-1.6.1-py3.7.egg
Processing dependencies for MAVProxy==1.6.1
Searching for pyserial>=3.0
Reading https://pypi.python.org/simple/pyserial/
Downloading https://pypi.python.org/packages/cc/74/11b04703ec416717b247d78910327
7269d567db575d2fd88f25d9767fe3d/pyserial-3.4.tar.gz#md5=ed6183b15519a0ae96675e9c
3330c69b
Best match: pyserial 3.4
Processing pyserial-3.4.tar.gz
Writing C:\Users\Etienne\AppData\Local\Temp\easy_install-73zg0pew\pyserial-3.4\s
etup.cfg
Running pyserial-3.4\setup.py -q bdist_egg --dist-dir C:\Users\Etienne\AppData\L
ocal\Temp\easy_install-73zg0pew\pyserial-3.4\egg-dist-tmp-mn75_nfz
zip_safe flag not set; analyzing archive contents...
  File "C:\Users\Etienne\AppData\Local\Programs\Python\Python37-32\lib\site-pack
ages\setuptools\sandbox.py", line 157, in save_modules
    yield saved
ages\setuptools\sandbox.py", line 198, in setup_context
    yield
ages\setuptools\sandbox.py", line 248, in run_setup
    DirectorySandbox(setup_dir).run(runner)
ages\setuptools\sandbox.py", line 278, in run
    return func()
ages\setuptools\sandbox.py", line 246, in runner
    _execfile(setup_script, ns)
ages\setuptools\sandbox.py", line 47, in _execfile
    exec(code, globals, locals)
  File "C:\Users\Etienne\AppData\Local\Temp\easy_install-73zg0pew\pyserial-3.4\s
etup.py", line 99, in <module>
    scripts=['serial/tools/miniterm.py'],
  File "C:\Users\Etienne\AppData\Local\Programs\Python\Python37-32\lib\distutils
\core.py", line 148, in setup
    dist.run_commands()
\dist.py", line 966, in run_commands
    self.run_command(cmd)
\dist.py", line 985, in run_command
    cmd_obj.run()
ages\setuptools\command\bdist_egg.py", line 209, in run
    os.path.join(archive_root, 'EGG-INFO'), self.zip_safe()
ages\setuptools\command\bdist_egg.py", line 245, in zip_safe
    return analyze_egg(self.bdist_dir, self.stubs)
ages\setuptools\command\bdist_egg.py", line 355, in analyze_egg
    safe = scan_module(egg_dir, base, name, stubs) and safe
ages\setuptools\command\bdist_egg.py", line 392, in scan_module
    code = marshal.load(f)
ValueError: bad marshal data (unknown type code)
During handling of the above exception, another exception occurred:
ages\setuptools\command\easy_install.py", line 665, in easy_install
    return self.install_item(spec, dist.location, tmpdir, deps)
ages\setuptools\command\easy_install.py", line 695, in install_item
    dists = self.install_eggs(spec, download, tmpdir)
ages\setuptools\command\easy_install.py", line 876, in install_eggs
    return self.build_and_install(setup_script, setup_base)
ages\setuptools\command\easy_install.py", line 1115, in build_and_install
    self.run_setup(setup_script, setup_base, args)
ages\setuptools\command\easy_install.py", line 1101, in run_setup
    run_setup(setup_script, args)
ages\setuptools\sandbox.py", line 251, in run_setup
    raise
  File "C:\Users\Etienne\AppData\Local\Programs\Python\Python37-32\lib\contextli
b.py", line 130, in __exit__
    self.gen.throw(type, value, traceback)
    yield
ages\setuptools\sandbox.py", line 169, in save_modules
    saved_exc.resume()
ages\setuptools\sandbox.py", line 144, in resume
    six.reraise(type, exc, self._tb)
ages\pkg_resources\_vendor\six.py", line 685, in reraise
    raise value.with_traceback(tb)
    yield saved
    yield
    return func()
    dist.run_commands()
    cmd_obj.run()
  File "C:\Users\Etienne\AppData\Local\Programs\Python\Python37-32\lib\shutil.py
", line 389, in _rmtree_unsafe
    os.unlink(fullname)
PermissionError: [WinError 32] The process cannot access the file because it is
being used by another process: 'C:\\Users\\Etienne\\AppData\\Local\\Temp\\easy_i
nstall-73zg0pew\\pyserial-3.4\\build\\bdist.win32\\egg\\serial\\threaded\\__pyca
che__\\__init__.cpython-37.pyc'
  File "setup.py", line 75, in <module>
    package_data}
    dist.run_commands()
    cmd_obj.run()
ages\setuptools\command\install.py", line 67, in run
    self.do_egg_install()
ages\setuptools\command\install.py", line 117, in do_egg_install
    cmd.run()
ages\setuptools\command\easy_install.py", line 410, in run
    self.easy_install(spec, not self.no_deps)
ages\setuptools\command\easy_install.py", line 646, in easy_install
    return self.install_item(None, spec, tmpdir, deps, True)
ages\setuptools\command\easy_install.py", line 697, in install_item
    self.process_distribution(spec, dist, deps)
ages\setuptools\command\easy_install.py", line 742, in process_distribution
    [requirement], self.local_index, self.easy_install
ages\pkg_resources\__init__.py", line 850, in resolve
    dist = best[req.key] = env.best_match(req, ws, installer)
ages\pkg_resources\__init__.py", line 1122, in best_match
    return self.obtain(req, installer)
ages\pkg_resources\__init__.py", line 1134, in obtain
    return installer(requirement)
ages\setuptools\command\easy_install.py", line 669, in easy_install
    rmtree(tmpdir)
ages\setuptools\command\easy_install.py", line 2227, in rmtree
    return shutil.rmtree(path, ignore_errors, onerror)
", line 507, in rmtree
    return _rmtree_unsafe(path, onerror)
", line 386, in _rmtree_unsafe
    _rmtree_unsafe(fullname, onerror)
  [Previous line repeated 3 more times]
", line 391, in _rmtree_unsafe
    onerror(os.unlink, fullname, sys.exc_info())
ages\setuptools\command\easy_install.py", line 1677, in auto_chmod
    six.reraise(et, (ev[0], ev[1] + (" %s %s" % (func, arg))))
TypeError: 'PermissionError' object is not subscriptable
There seems to be a lot of errors scrolling to this text.
