A little help on setting up a PWM Relay Switch?
Hello all. It seems like this should be pretty easy to do but I’m obviously missing something. I’d like to use a PWM Relay Switch like this: https://hobbyking.com/en_us/turnigy-tx-controlled-relay-switch.html to operate a simple laser scaler via the gamepad - idealy using a shift/button combination just to turn the scaler on and off . The physical portion of the project is no problem and mostly done. Would anyone be willing to walk me thru the ArduSub/QGC setup?
In ArduSub 3.4, this can be done by re-purposing the ‘video source toggle’ joystick button function.
  1. Configure a button with the camera_source_toggle function
  2. Plug your signal cable for the relay into Aux output 1 on the Pixhawk
  3. Set the RC9_FUNCTION parameter to RCIN11
In 3.5 (coming soon), you will be able to configure buttons to control generic pwm output functions and set output pins low/high for relays.
Thanks for the reply, Jacob. Unfortunately, no joy with your recommendation. I may try some more with 3.5 although, I’m thinking it may be a better strategy to use a simple relay off the RPi GPIO’s and just control the switching with a keystroke.
