Wiring t200 on a kayak
3-pin Power: 400 VDC, 20 amps per pin
will this work for 1 t200?
Cobalt Series Bulkhead Connector
Hi @catdog -
Yes that’s is the connector I linked you to in the thread discussing your kayak. That is the end that goes on your enclosure, the opposite end is soldered and potted to your existing thruster cable. You want to use the three pin, power rated cobalt connector.
