Hello! I was wondering if there is a minimum thickness of the wall when using a wetlink penetrator. I tried looking on the product page but couldn’t find any info on this. Where I want to install one of these penetrators, the thickness of the wall is only 1,5 mm.
Hi @Severholt,
I’m not sure which wall of the penetrator you’re referring to, and I’m also not sure how the thickness of an individual wall on the wet side is relevant. The penetrator assembly is in compression when in the water, and does not have chambers/bubbles of highly compressible material (e.g. air, uncompressed foam, etc) that would cause parts of it to take on significant bending or shear stresses.
Could you explain a bit more what you’re concerned about, and clarify (preferably on a diagram or image of the penetrator) what you’re considering to be at risk? ![]()
Hey Elliot the way i read Mr. Severholts post is he is questioning minimum wall thickness of the enclosure/structure he would like to use the penetrator through. I appologize in advance if im mis-reading his question and he infact wishes to know the tube wall thickness of the described penetrator.
If that is the case, I don’t see why there would be a minimum installation wall thickness, as long as the material of the wall is sufficiently stiff and strong to withstand the liquid pressure being exerted on it ![]()
That said, the question was posted a couple of years ago, so it seems unlikely we’ll get a clarification of the poster’s intent now.
