Hi guys,
is it possible to replace the switch with a potentiomètre inside this: https://www.bluerobotics.com/store/comm-control-power/switch/switch-10-5a-r1/
Also, will the switch operate at depth.
Cheers,
Etienne
Hi guys,
Cheers,
Etienne
Hi Etienne,
The switch body is not design to accommodate a potentiometer, the way it has to go together makes it not possible to install one. It may be possible to do so by modifying it and removing/adding some features, making a dedicated potentiometer version is on our long term list.
Can you clarify your second question? The plug screws in and out with an o-ring to seal to depress the switch, it may be very difficult to screw in and out under pressure though, it was not designed for this.
-Adam
Hi Adam,
You’ve answered all my questions.
I also suspected that the pressure would prevent turning the switch under water
Thank you.
