I am trying to control my blue boat with my own custom back seat software by creating a BlueOS extension. I want to have ArduPilot (ArduRover 4.5.4) running for its state estimation (sending my backseat gps information, attitude data etc) while also using the navigator library to control the thrusters. I seem to be having a problem with ArduPilot fighting with the navigator library for control over the PWM pins. I can control both thrusters just fine using the navigator library but the second I turn the autopilot back on I only have control over one thruster (the lowest channel number being set by the navigator) all other pins are unresponsive.
Is there a way to totally bypass Ardupilot’s PWM control? I have every SERVOX_FUNCTION set to disable but that doesn’t seem to make a difference.
Here is the code I am trying to run (with the hopes of more than one pin being responsive to the navigator library)
import signal
import time
import os
from datetime import datetime, timedelta
import bluerobotics_navigator as navigator
from bluerobotics_navigator import PwmChannel
# Constants
PWM_FREQ_HZ = 50
MAX_VAL = 409.5 # at 50 Hz, corresponds to 2000 microseconds pulse width
MIN_VAL = 204.75 # at 50 Hz, corresponds to 1000 microseconds pulse width
CENTER_PWM = MIN_VAL + (MAX_VAL - MIN_VAL) / 2
RANGE_PWM = MAX_VAL - MIN_VAL
INCREMENTS = 150
STEP_SIZE = MAX_VAL / INCREMENTS
SERVO_SPAN = 154 * 2 / 3 # degrees - per datasheet should only operate around 110
SERVO_SWING = SERVO_SPAN / 2
SERVO_INCREMENT = SERVO_SPAN / INCREMENTS
ESC_CHANNELS = [PwmChannel.Ch1,PwmChannel.Ch2,PwmChannel.Ch3,PwmChannel.Ch4,PwmChannel.Ch5,PwmChannel.Ch6, PwmChannel.Ch7, PwmChannel.Ch8]
HOLD_TIME = 5 # seconds
def set_pin_pulse_width(pin_num, target):
Set the PWM pulse width for the specified pin.
Args:
pin_num (PwmChannel): The PWM channel number.
target (float): Target percentage (-100 to 100).
pulse_width = CENTER_PWM + (target / 100.0) * RANGE_PWM / 2
navigator.set_pwm_channel_value(pin_num, int(pulse_width))
def get_initialize():
"""Checks to see if board has been initialized"""
if os.environ.get("CI") == "true":
print("Not Initialized")
return False
else:
print("Board already initialized")
return True
def center_servos():
"""Center all servo channels."""
for channel in ESC_CHANNELS:
set_pin_pulse_width(channel, 0)
def initialize_esc():
"""Calibrates each esc: set max, set min, set center"""
set_pin_pulse_width(PwmChannel.Ch10, 100)
set_pin_pulse_width(PwmChannel.Ch12, 100)
set_pin_pulse_width(PwmChannel.Ch14, 100)
time.sleep(0.5)
set_pin_pulse_width(PwmChannel.Ch10, -100)
set_pin_pulse_width(PwmChannel.Ch12, -100)
set_pin_pulse_width(PwmChannel.Ch14, -100)
time.sleep(0.5)
set_pin_pulse_width(PwmChannel.Ch10, 0)
set_pin_pulse_width(PwmChannel.Ch12, 0)
set_pin_pulse_width(PwmChannel.Ch14, 0)
time.sleep(0.5)
def signal_handler(signum, frame):
Handle signal interrupt (e.g., Ctrl+C) by centering servos and disabling PWM.
Args:
signum (int): Signal number.
frame (frame object): Current stack frame.
center_servos()
time.sleep(0.5)
navigator.set_pwm_enable(False)
exit(signum)
def main():
# Set up signal handling
signal.signal(signal.SIGINT, signal_handler)
# Initialize Navigator
navigator.init()
navigator.set_pwm_freq_hz(PWM_FREQ_HZ)
navigator.set_pwm_enable(True)
print(f"PWM Chip State: {navigator.get_pwm_enable()}, waiting for a second")
time.sleep(3)
#Initialize ESCs
print("Calibrating ESCs")
initialize_esc()
# Center SERVOs initially
print("Centering SERVOs")
center_servos()
# Hold the center position for a while
hold_until = datetime.now() + timedelta(seconds=HOLD_TIME)
while datetime.now() < hold_until:
time_left = (hold_until - datetime.now()).total_seconds()
print(f"T - {time_left:.2f}")
time.sleep(1)
# PWM sweeping logic
i = CENTER_PWM
increasing = True # Initial direction
next_update = datetime.now()
while True:
if datetime.now() >= next_update:
set_pin_pulse_width(channel, (i - CENTER_PWM) * 100 / RANGE_PWM)
servo_angle = ((i - CENTER_PWM) / RANGE_PWM) * SERVO_SWING
print(f"Set {servo_angle:.2f}")
if increasing:
i += STEP_SIZE
if i >= MAX_VAL:
i = MAX_VAL
increasing = False
else:
i -= STEP_SIZE
if i <= MIN_VAL:
i = MIN_VAL
increasing = True
next_update = datetime.now() + timedelta(milliseconds=50)
if __name__ == "__main__":
main()
