Hey all,
I am using T500 thrusters with basic esc 500 ESC.
After giving forward signal, the thruster responses to the signal and moves forward. But when I give the neutral signal it doesn’t stop spinning. My autopilot is sending 1500 PWM signal but the thruster is not coming to rest.
Once I put the thruster in reverse direction and then back to neutral the thruster comes to rest.
Is there some way I can troubleshoot this and find the cause and possible solution?
I have tried with 4 ESC… And 2 of them used to work fine… But they have given up after using for a long period… I put the new 2 ESC but both are having the above issue…
Does anyone have a idea what’s going on?
