T200 Efficiency
Good day,
I’m doing calculation based on T200 specs and spreadsheets in excel (T200-Public perfomance). This document has a column named efficiency, what kind of efficiency is noted here propeller, motor or full system (motor + propeller) ?
Given that it’s performance data for the thruster, and is plotted against the PWM input signal in the technical details, I’d assume it’s for the full system (ie thrust efficiency). They’re selling the thrusters, and don’t sell the motors individually, so not much point giving detailed motor specs without corresponding specs for the system as a whole.
Hi @Diell,
The efficiency is the output thrust over the input power (g/w).
-Adam
Hi Adam,
Got it thanks!
Thanks. My first thoughts were the same that is for a whole system, just wanted to be sure.
