I recently bought 2 x T200 and 2 x Basic ESCs that I want to use in skid steering with a Holybro Pixhawk 4 running ArduRover. For Tx/Rx I am using a FrSky X9 Lite and a X8R.
I configured everything in QGroundControl and here is a list of parameters that I’ve changed.
SERVO1_FUNCTION = 73
SERVO1_FUNCTION = 74
Currently, I have the ESCs connected to the Holybro FP07 power distribution board (motors 1 and 3) but I am not getting any response from the T200s.
When I apply power, the ESCs beep, but then absolutely nothing happens when I arm and move the sticks on the transmitter. I have calibrated the X9, both on the transmitter side and in QGC. I also tried setting subtrims so that PWM from channels 1 and 3 range exactly from 1100 to 1900. Still nothing from the T200s.
My question then- is this a power distribution issue, or something else? Before I unsolder the ESCs from the PDB and connect directly to the battery I thought I would get some feedback.
According to our Basic ESC Quick Start, it sounds like the ESCs are intializing:
Send a stopped signal (1500 microseconds) for a few seconds to initialize the ESC. You will hear two tones indicating initialization, and then you can send a signal from 1100-1900 µs to operate the thruster.
Wha you have going on sounds like an ArduRover or Pixhawk4 issue. I recommend asking in the ArduRover/ArduBoat forums if you have not already done so. Nobody on the Blue Robotics staff has a Pixhawk 4 to test and replicate your setup.
