Hello, all,
This year for the MATE competition our team will be using your T-100 thrusters. We do have a few questions about them though.
What is the minimum mass of an ROV that could be precisely maneuvered be two T-100s? Why would a T-100 not respond until a significant amount of throttle was given to it? Should the t-100s be able to operate low RPMs like 60 RPM?
What would cause a T-100 to surge to high speeds and reverse directions when not being given any throttle for a minute then stop and not respond to anything? A PWM signal out of range? Too low of a voltage on the signal line? Too fast of a refresh rate on the PWM signal?
This would depend on the vehicle shape, density, and dynamics. A better question to ask is how much thrust does the T-100 produce? The answer can be found in the product specifications.
This is not a property of the motor, but the electronic speed controller. Some electronic speed controllers have a dead band where they will not produce any output. This will also depend on the power being sent to the thruster for example, if your supply is a AA battery, that might not provide enough power to produce the torque necessary to turn the motor.
Again, this is dependent on the electronic speed controller. Usually speeds this low are only possible with ESCs that operate with Field Oriented Control (FOC).
This sounds like you have spurious/unwanted signals going to the ESC. It is very unlikely that this would happen otherwise. You should verify your software, and physical connections/continuity of wiring. An oscilloscope or logic analyzer will reveal the issue immediately.
