Serial Port Quantity
Hi
I’m currently using the Navigator Flight Controller for underwater equipment development, but the number of serial ports available on the development board is not sufficient for all of our sensors. I’d like to ask if there are any related expansion products or methods to add more serial ports.
Thanks.
Hi @XiangHong,
The Navigator’s serial ports are from the underlying raspberry pi. They can’t be directly expanded, but it’s possible to make links to some alternatives:
That said, depending on the hardware you’re using, you may also wish to consider multi-bus protocols like I2C, so multiple peripherals can share a connection to a single port.
