Send Rc to Pixhawk
Hello friends,I want to send rc values to Pixhawk from Raspberry Pi,I found this code but ı want to serial communication instead of Udp how can ı change this code thanks a lot
Import mavutil
from pymavlink import mavutil
Create the connection
master = mavutil.mavlink_connection(‘udpin:0.0.0.0:14550’)
Wait a heartbeat before sending commands
master.wait_heartbeat()
Create a function to send RC values
More information about Joystick channels
here: Redirecting...
def set_rc_channel_pwm(id, pwm=1500):
“”" Set RC channel pwm value
Args:
id (TYPE): Channel ID
pwm (int, optional): Channel pwm value 1100-1900
if id < 1:
print(“Channel does not exist.”)
return
# We only have 8 channels
# https://mavlink.io/en/messages/common.html#RC_CHANNELS_OVERRIDE
if id < 9:
    rc_channel_values = [65535 for _ in range(8)]
    rc_channel_values[id - 1] = pwm
    master.mav.rc_channels_override_send(
        master.target_system,                # target_system
        master.target_component,             # target_component
        *rc_channel_values)                  # RC channel list, in microseconds.
Set some roll
set_rc_channel_pwm(2, 1600)
Set some yaw
set_rc_channel_pwm(4, 1600)
replace the connection string: udpin:0.0.0.0:14550 → /dev/ttACM0 or whatever your serial port is.
master = mavutil.mavlink_connection(‘/dev/ttyACM0’)
thanks a lot
