Re: External lights - Does anyone Have Experience adding Lights to BlueROV?
I have two thoughts.
- I bought two small circuits on ebay with 12vdc leds I was thinking we could pot these with epoxy, running the cable thru a penetrator. Since most of these are designed to run off the battery of a car, they should be OK at 12-15 volts or so. Many types available http://www.ebay.com/itm/24SMD-5730-LED-White-Light-Panel-Board-Auto-Interior-Map-Dome-Reading-Lamp-12V-/371321836086?hash=item5674819236:g:lpIAAOSwrklVStZo&vxp=mtr
- A second option we have not evaluated is to use waterproof led strip lights such as the following have not tested whether these will handle depth pressure. See http://www.ebay.com/itm/2x-50CM-Super-Bright-SMD-5630-White-30-LED-Waterproof-Flexible-Strip-Lamp-DC-12V-/201558666454?hash=item2eedd52cd6:g:rLUAAOSwgQ9VsdtJ
Paul
