Hi everyone! I’m new to the forum, and I’m trying to some example code using the Blue Navigator Flight Controller for an ArduSub.
Here’s what Im running:
- Raspberry Pi 4b
- Navigator Flight Controller
- Blue OS 1.4.2
- Using Jupyter to run code
import os
import platform
import bluerobotics_navigator as navigator
from bluerobotics_navigator import AdcChannel, UserLed
from bluerobotics_navigator import NavigatorVersion, Raspberry
navigator.set_navigator_version(NavigatorVersion.Version1)
navigator.set_raspberry_pi_version(Raspberry.Pi4)
def navigator_check():
print(f"Functions available: {navigator.__all__}")
if os.environ.get("CI") == "true":
print("Running in CI")
print("Not possible to test navigator sensors yet.")
return
print("Initializing navigator module.")
if platform.machine() == "aarch64":
# It's possible to set the configuration before initializing the navigator, check this example
print("Setting up for Navigator V2 on Raspberry Pi 5")
navigator.set_rgb_led_strip_size(1)
navigator.set_navigator_version(NavigatorVersion.Version2)
navigator.set_raspberry_pi_version(Raspberry.Pi5)
navigator.init()
print("Setting led on!")
navigator.set_led(UserLed.Led1, True)
print(f"Temperature: {navigator.read_temp()}")
print(f"Pressure: {navigator.read_pressure()}")
print(f"Leak sensor: {navigator.read_leak()}")
Data = navigator.read_adc_all()
print(
f"Data ADC Channels: 1 = {Data[0]}, 2 = {Data[1]}, 3 = {Data[2]}, 4 = {Data[3]}"
print(f"Data ADC Channel: 1 = {navigator.read_adc(AdcChannel.Ch1)}")
Data = navigator.read_mag()
print(f"Magnetic field: X = {Data.x}, Y = {Data.y}, Z = {Data.z}")
Data = navigator.read_accel()
print(f"Acceleration: X = {Data.x}, Y = {Data.y}, Z = {Data.z}")
Data = navigator.read_gyro()
print(f"Gyroscope: X = {Data.x}, Y = {Data.y}, Z = {Data.z}")
print("Setting led off!")
navigator.set_led(UserLed.Led1, False)
if __name__ == "__main__":
navigator_check()
Im trying to run this code and then this is the output I get
Functions available: ['AdcChannel', 'UserLed', 'AxisData', 'Raspberry', 'NavigatorVersion', 'init', 'set_rgb_led_strip_size', 'set_navigator_version', 'set_raspberry_pi_version', 'self_test', 'set_led', 'get_led', 'set_led_toggle', 'set_led_all', 'set_neopixel', 'set_neopixel_rgbw', 'read_adc_all', 'read_adc', 'read_pressure', 'read_temp', 'read_leak', 'read_mag', 'read_accel', 'read_gyro', 'set_pwm_enable', 'set_pwm_freq_hz', 'set_pwm_channel_value', 'set_pwm_channel_duty_cycle', 'set_pwm_channels_value', 'set_pwm_channels_duty_cycle', 'set_pwm_channels_values', 'set_pwm_channels_duty_cycle_values']
Setting led on!
thread '<unnamed>' panicked at 'Failed to create Bmp280: Other(())', /root/.cargo/registry/src/index.crates.io-6f17d22bba15001f/navigator-rs-0.6.0/src/lib.rs:442:22
PanicException Traceback (most recent call last)
Cell In[15], line 61
57 navigator.set_led(UserLed.Led1, False)
60 if __name__ == "__main__":
---> 61 navigator_check()
Cell In[15], line 32, in navigator_check()
29 navigator.init()
31 print("Setting led on!")
---> 32 navigator.set_led(UserLed.Led1, True)
34 print(f"Temperature: {navigator.read_temp()}")
36 print(f"Pressure: {navigator.read_pressure()}")
PanicException: Failed to create Bmp280: Other(())
It keeps on trying to create the Bmp280 but I know the Navigator is running a BMP390. What can i do about this to fix it?
