PM07 + Basic ESC
Hi.
The Basic ESC has two signal cables. One black and one white. I have a PM07 board, but it only wants one cable for signal. Do I just skip the black signal wire and solder the white one only?
Hi @uchiha,
The wire which actually caries the signal is the white one. The black wire is the reference wire, so should be connected to ground :slight_smile:
Is it ok to twist it together with the thicker black wire and solder them together?
Yes, that should be fine :slight_smile:
