Ping Viewer Connection Issues Across Sub-Nets
Ping-Viewer is able to find the sensor over the network via broadcast message, that is not connected to the subnet issue that we are talking about.
As you can see, no network interface in your machine has a valid IP address inside the subnet address of the sensor, probably your VPN software uses the windows API to allow the connection to work for others softwares.
I have created a version of ping-viewer that disables the subnet check, you can check it here.
Let us know if that works.
Hi @patrickelectric,
Everything worked great on this update. Thanks for the support!
Log file:
20211214-100626981.txt (6.2 MB)
Hi @almathisen,
Thanks for reporting the issue and sending the log!
We now have a new ping-viewer version with the fix.
