Ping sonar refresh rate
What is the refresh rate of the ping sonar (the cheap version not the 360)?
Putting it simply, how many fresh accurate readings per second?
Some ultrasonic sensors display faulty measurements when rotated at high speeds, i intend to rotate it to get - say - a 180 degrees scan.
It can range from ~.5hz to ~30Hz depending on the conditions and device configuration. Check the user manual for more information
