Here you go! I threw this together on a Mega 2560. All you need to do is hook it up to Serial1 and then change out the serial port and baud rate.
Connections:
Ping White TX wire → Serial1 RX (Pin 19)
Ping Green RX wire → Serial1 TX (Pin 18)
Code
#include "ping1d.h"
static const uint8_t arduinoRxPin = 19; //Serial1 rx
static const uint8_t arduinoTxPin = 18; //Serial1 tx
static Ping1D ping { Serial1 };
static const uint8_t ledPin = 13;
void setup()
Serial1.begin(115200);
Serial.begin(115200);
pinMode(ledPin, OUTPUT);
Serial.println("Blue Robotics ping1d-simple.ino");
while (!ping.initialize()) {
Serial.println("\nPing device failed to initialize!");
Serial.println("Are the Ping rx/tx wired correctly?");
Serial.print("Ping rx is the green wire, and should be connected to Arduino pin ");
Serial.print(arduinoTxPin);
Serial.println(" (Arduino tx)");
Serial.print("Ping tx is the white wire, and should be connected to Arduino pin ");
Serial.print(arduinoRxPin);
Serial.println(" (Arduino rx)");
delay(2000);
void loop()
if (ping.update()) {
Serial.print("Distance: ");
Serial.print(ping.distance());
Serial.print("\tConfidence: ");
Serial.println(ping.confidence());
} else {
Serial.println("No update received!");
// Toggle the LED to show that the program is running
digitalWrite(ledPin, !digitalRead(ledPin));
Hope that works for you
