We’re considering using sector scans from the Ping 360 as part of dock inspections, to measure pile profiles and estimate the cross-section at different depths by scanning from multiple sides. I’ve had a look at the documentation and it looks like the device_data messages are sent at each motor angle (since the angle field is singular), which the ping viewer application then stitches together into an image for visual display.
Is this correct i.e. during a scan we’d get several data messages sent throughout rather than just one full image message at the end? If that’s the case we can potentially use the IMU data to account for any minor position changes while scanning
The technical details in the specification say a 2m scan distance takes 9s for a full revolution, with the expectation that the scan time will be reduced through software optimisations. Curious as to whether there’s an estimate for how much that will be reduced by, and if it’s planned as near term or in a year or something.
The minimum distance is specified as 0.75m at the moment. Presumably that’s a processing speed limit, but is that likely to decrease with the intended software optimisations, or are the optimisations more to do with motor movement than improving processing time?
A continuous 360 degree scan is possible, but is continuous bouncing sector scanning possible, or does the motor only go one way? If it’s two-way and we request a scan from 350 to 10 degrees, how does it know which way to turn? If it’s one-way presumably the motor can move quickly from the end of one scan sector to the start of the next one in the region where it’s not scanning?
