Network Connection into the BlueBoat - Options
Hi @nogu -
This should be possible, but you’ve got the direction of the BaseStation and BlueBoat Mikrotik radio backwards- the BaseStation is the AP, and the Boat is the client (this proved to work much better when operating at long ranges.)
Perhaps your Teltonika RUTX50 could be configured to access the BaseStation network as a client? Alternatively, you could configure the BaseStation Mikrotik to act as a client to the Teltonika, but this is a non-standard configuration and I’m not sure the best settings to use - a LLM AI would provide good advice though, it’s fairly handy with RouterOS devices.
The proxy extension may also be useful - if you access BlueOS via ZeroTier or some other means, you can then access devices on the local ethernet network via it…
Hi @jwenger -
Sorry I missed getting back to you on this. You can special order the bulkhead connector from us, the part # is BR-101324.
Please add this Special Request item to your cart. Enter billing/shipping information and specify the item SKU and quantities needed in the customer notes. At check out, Request a Quote instead of paying for the order:
A sales representative will return the quote with the total cost, including shipping and a payment link.
