Yeah, it’s just connected with USB. It doesn’t need to sit on the Pi’s GPIO header
Just managed to setup ZeroTier “multipath” between WiFi and Cellular networks on the bench. As a temporary solution I will try to mount the included sma antenna through a M10 hole.
Working towards a more permanent solution, I am reluctant to use a bell shaped antenna, as these are not removable and are intended to be mounted on a pole or already be positioned high enough. So I intend to follow the existing setup and install a N-Type bulkhead connector, which is by default “weatherproof”, and mount an antenna like this one (alpha aoa-4g-8m) or preferable a foldable like the built-in WiFi one, if I manage to source one. If not, I can remove it for transportation.
I also noticed that there are “multiband” antennas that serve both 4G/LTE (800-2600MHz) and WiFi (2400MHz). Do we have a part# for the builtin antenna so we can lookup the specs and possibly source a similar one?
Costas
Hi @cyamin -
Glad you got that setup - pretty easy huh?
Getting co-ax connectors into the vehicle is a pain - to me it seems easiest to either go with something big like the N-Type we’re using, or cut the cable, pass it through a WetLink, and re-terminate it on the other side. I’ve been using dual “bell” antennas (see link in earlier post) on the deck of my Blue Boat- they have an o-ring face seal on the underside and fit the 14mm penetrator holes nicely. I’m not sure what you mean when you say they aren’t removable? I haven’t done any major missions to test the range, but was operating over 1 mile from shore without issue!
Regardless, especially for WiFi, antenna height can play a major role in range. The Omni antenna that comes with the Blue Boat only has one “specification” besides its N-Type connector, a gain value of 7 dB. Multi-band antennas are cool, and definitely seem worth testing if you’re trying to get more out of a single penetrator - ideally they’d have internal connectors for each frequency range? You could adapt the antenna protector mount to work with a different diameter antenna potentially, if you want to keep it folding down or just give the connector some strain relief.
Hi Tony,
It was fairly easy because there’s plenty info online! Raspberry Pi and linux is not something I know.
Well I meant that you cannot readily detach from the hull without having to open the hull and disconnect the cables. I intend following the existing design by installing two N bulkheads, permanently fix the cables below decks and screw the antennas on top prior to each use. Antennas sticking out are looking forward to getting broken.
Sometimes you get better reception “offshore” when there are no obstructions. I usually have problematic cellular reception “nearshore” in rough terrain. So I try to do the best I can on my side and most probably check directional WiFi antennas for the BaseStation.
The proper ones do, like this one. Of course, you can’t excel in all bands. Also it seems a 4G/LTE antenna is inherently fit for 2.4GHz WiFi but not the other way round.
Hi everyone,
About the connection between the Blue Boat and the Base Station… I haven’t got the chance to figure out and setup the Blue Boat to be equipped with 4G cellular connection (with ZeroTier)… I am wondering on whether it is possible to setup the Base Station (+ laptop) on the deck of a small watercraft (inflatable boat, skiff or stable kayak).
So, as the Blue Boat starts to loose line of sight to the Base Station … blocked by trees, structure or becomes too far away from the Base Station… I can steer the the water craft with the Base Station on it closer to the Blue Boat to maintain good connection.
Like in this Blue Boat youtube video in minute 1:16, where the Blue Boat was launched from an inflatable boat.
The cases that I am thinking is in doing surveys at a marina, harbor, canals or coastal area with mangroves…
Hi @knarotama
You can absolutely use the base station from a boat, following the Blue Boat! This is a great way to overcome range limitations and more importantly keep an eye on the vessel, especially if it will be navigating in high traffic areas or regions with obstacles. You’ll want to put the base station antenna as high as possible to maximize range. It’s much like using an rov on a boat!
Thank you @tony-white
Hi All,
We just tried out mounting the base station on top of a telescopic pole, tied & clamped to a tandem kayak to control the Blue Boat, simulating survey in an estuary/mangrove canals.
The telescopic pole helped since we need to go under a low bridge.
The Blue Boat lost connection to the control station at a distance of ~ 30-40 meters from the kayak, the height of the pole was like in the picture above. Extending the pole added an additional height of ~ 40/50 cm and we can say that this increased the wireless range to ~ 40-50 meters.
Some ideas to improve this setup are to use:
- A longer telescopic pole, stiff yet light weight (probably a 3 meter selfie stick)
- Wifi 2.4 GHz extension cable with N-type connection. The base station box would sit on the deck of the kayak, running the extension cable along the pole and the antenna piece at the top of the pole.
Question: Would using a 9 dbi (instead of the 7 dbi that comes in package) or a higher dbi antenna helps?
At the end of the mangrove canals, where the river meets the sea, is a zone with high rise buildings… and in that area we experienced lost connection even when Blue Boat is only about 15-20 meters from the Base Station. We suspect that we experienced signal interference… so we still intend to integrate a 4G and telemetry connection also…
Hi @knarotama -
You can find some documentation on the ZeroTier BlueOs Extension page - let us now if you have any issues following it!
Thank you @tony-white, @williangalvani and @cyamin
Today we managed to install 4G USB modem (Huawei E3372) and setup ZeroTier “broadcast” to the Blue Boat system + satisfactory “dry test”. We plan to test the 4G setup in the field/water
next week.
We followed this ZeroTier documentation (from @tony-white) along with this Blue Boat LTE setup guide for Japan. For the QGC connection, we are currently using the “UDP Client link/MavLink Endpoints” instead of the BlueOS’s GCS Server Link as per advice from the ZeroTier documentation.
Continuing the improvement to our “follow along base station setup”. We did use a lightweight 3 meters telescopic pole (insta360 selfie stick) along with a Wifi 2.4 Ghz extension cable. The setup increases the wireless range to ~ 90-100 meters.
Hi @knarotama -
That’s great to hear! You can verify the usb modem is working ok by using it to ping. Go to the terminal, and type red-pill, and press enter. then type:
ping -I usb1 8.8.8.8
You may have your modem connected on another usb device - usb0 or usb2? But the command should complete some successful pings if the modem is setup correctly. If not, please share!
As for your WiFi range, that still seems a bit short. Have you verified your BaseStation is set to 12V internally, as this technical bulletin mentions?
We tested it at a coastal area for bathymetry survey . During pre-mission check, the 4G USB modem did not work. We may need to mount 4G antennas on the Blue Boat.
So, we resorted to the BaseStation (wifi connection), BaseStation was already set to 12V (factory default). Using extension cable at a height of ~5 meters, distance was max ~-240 meters.
We used the ping2Survey to record the data and QGC for mission planning. Total survey area is ~ 7 hectares, we setup the BaseStation from two locations and then processed the data in QGIS.
Very cool @knarotama -
Sorry the 4G didn’t work - had it worked in another location with better signal previously, or had you not verified that with the Ping -I command?
I got the hardware Tony suggested working on my BlueBoat, however I have noticed running the vehicle uses a ton of data. I was curious if anyone else has seen this, or knows of a way to lower data usage.
I tested the vehicle yesterday, it was on and connected for perhaps about 6 hours and used ~13 GB of data. The boat has a camera onboard, however QGC streaming was turned off (I changed the destination IP address to something that did not exist). I did have the blueos web page open, but generally not to the video streams page. Presumably the video preview only is sent to blueos.local if the video page is open?
Any other ways to reduce data usage? I see there are a bunch of Autopilot parameters that correspond to stream rate (Ex. SRX_PARAMS = 10Hz), will lowering these help significantly? I don’t need fast updates in the slightest when running missions.
Side note - I would love it if BlueOS had an option to stream at 1 FPS to reduce data usage.
Hi @PatrickMcGuire -
That is about 6x more data than I’ve seen for typical operations, even with sonar! I would bet your camera is the culprit, unless you performed any software updates via the cellular connection? Setting the IP address to something that didn’t exist may not have disabled things - you may want to remove the stream from the Video Streams page entirely when not in use?
I agree a 1FPS option would be great for BlueBoat usage!
I wouldn’t expect lowering your stream rates to have a significant affect on your data consumption, but it may be worth experimenting with. You do need even higher rates for Sr0 when using sonars in some cases!
Thank you @tony-white & @williangalvani!! We (finally) did a Blueboat mission using 4G connection with ZeroTier (+ Ping2 and Cerulean 450 SS). I think this mission will take longer to finish should we only use the standard BaseStation setup.
We put a Huawei E5577 (mifi hotspot) inside the starboard hull’s electronic tray. The modem has 2 antenna slots, we connected each of the slot to a Bingfu 4G LTE Antenna (as per this post & they do fit nice through the M14 holes on the hatch lid). BlueOS auto-connects to the modem everytime it turns ON.
Hi William, please describe your 900 MhZ telemetry system with more details. Thanks!
Hey @tony-white,
Any chance there is a purchasable n-type bulkhead connector or at least a manufacturer / part number? Looking to replace mine and get a few extras… Thanks!
Hello everyone!
I am in the process of enabling 5G connectivity for the BlueBoat, but I have now met some challenges. In my setup I am using a Teltonika RUTX50 for the 5G connectivity to the BlueBoat, as well as for communications onboard between the NORBIT survey equipment and the computer used for data collection. The latter is remotely controlled from land. Because we sometimes operate in remote areas with poor or no cellular connection, we need to be able to access the onboard network via WiFi as well. I was hoping that it would be possible to get the BaseStation to connect directly to the RUTX50 via WiFi to extend the whole network to the ground station computer, but I can’t seem to figure out how to achieve this.
Has anyone achieved a similar setup?
I guess an option is to include the Mikrotik onboard the BlueBoat in the setup somehow, but I was hoping to work my way around this as I am trying to save as much weight as I can.
