We are building a rover with the 6 thruster BluRov2/ vectored configuration, and want to use the default joystick configuration for this frame. One of the issues we keep across is that the attached errors is that this windows in this order from top to bottom pops. We select “use the value from Bluos” option, the the page reloads but the same error pops up, and it does this in a loop. any advice on how we can troubleshoot this would be greatly appreciated.
Hi @bdaqiq -
This is a bug in that version of Cockpit - please update to the latest! Alternatively, you select “Keep Cockpit’s Value” and likely get into the interface normally.
