We have a BAR30 attached to an Odroid USB IO board.
http://www.hardkernel.com/main/products/prdt_info.php?g_code=G135390529643
This has an I2C capability described here:
two files that are key are:
(the interface code)
(an example I2C interface)
So I think what i need to do is get a version of the code here:
translated so it communicates via the USBIO/I2C rather than the SMBUS.
For example:
self._bus.read_word_data(self._MS5837_ADDR, self._MS5837_PROM_READ + 2*i)
I assume reads something (a single byte?) from the I2C,
The functions I need to translate are:
self._bus.write_byte(self._MS5837_ADDR, self._MS5837_CONVERT_D1_256 + 2oversampling)
self._bus.read_word_data(self._MS5837_ADDR, self._MS5837_PROM_READ + 2i)
self._bus.read_i2c_block_data(self._MS5837_ADDR, self._MS5837_ADC_READ, 3)
What is the equivalent call from the HK library? (all the calls available are below)
I think I’m pretty close on this (from a theoretical point of view) but I am completely out of my depth (ha!) from an I2C standpoint.
Any help would be greatly appreciated!!!
def i2c_init(dev): # init i2c
dev.write(1,[u_i2c_init], 100)
def i2c_idle(dev): # i2c idle
dev.write(1,[u_i2c_idle], 100)
def i2c_start(dev, cval): # i2c start
a = array('B',[0,0,0,0,0,0,0,0,0,0,0,0,0,0])
a[0] = u_i2c_strt
a[1] = cval
dev.write(1, a, 100)
def i2c_stop(dev): # i2c stop
dev.write(1,[u_i2c_stop], 100)
def i2c_slave_ack(dev): # i2c slave ack
dev.write(1,[u_i2c_slak], 100)
ret = dev.read(0x81, 64, 100)
return ret[1] # 1=no ack, 0=ack
def i2c_write(dev, cval): # i2c write
a[0] = u_i2c_writ
a[1] = cval
def i2c_master_ack(dev, cval): # 1=nack, 0=ack
a[0] = u_i2c_mack
a[1] = cval
def i2c_read(dev): # i2c read
dev.write(1,[u_i2c_read], 100)
return ret[1] # i2c_read char
def i2c_isdatardy(dev): # check if i2c char avail
dev.write(1,[u_i2c_dtrd], 100)
def writeRegister(dev_addr, addr, value):
i2c_start(usb, I2C_START_CMD)
i2c_write(usb, (dev_addr << 1 | I2C_WRITE_CMD))
while (i2c_slave_ack(usb)):
time.sleep(0.1)
# select the register to write to
i2c_write(usb, addr)
time.sleep(0.1)
# write the value to the previously selected reg
i2c_write(usb, value)
time.sleep(0.1)
i2c_stop(usb)
def readRegister(dev_addr, addr):
while (i2c_slave_ack(usb)): # wait for slave ack
time.sleep(0.1)
# select the register address to read
time.sleep(0.1)
i2c_start(usb, I2C_REP_START_CMD)
i2c_write(usb, (dev_addr << 1 | I2C_READ_CMD))
# read the value from the register
time.sleep(0.1)
a = i2c_read(usb)
# ack the byte
i2c_master_ack(usb, I2C_DATA_NOACK)
i2c_stop(usb)
return a
