Awesome thanks Eliot! We have a field trip to the Coral Sea in October and it would be great if we can integrate some of these into our BR2. The main thing I am aiming to do is set up a tether quick disconnect. The discussion on this appears to have dried up although it looks like you guys were planning on developing such a system over 5 years ago Tether Quick Disconnect - #17 by rjehangir. However I was thinking that the WLP might help with this - all the existing wet ports for bulk heads out there appear to be in imperial measurements so I thought if I can find a system that has a cable with a suitable OD then I could use that in conjunction with the WLP. That would at least sort out how to install into the enclosure. Then i just need to figure out how to splice the other part into the tether!!
