There’s some discussion on Python scanning speeds here, but it should definitely be much faster than that unless you’re either setting a variable incorrectly (e.g. if your scale is off by an order of magnitude or something), or having communication issues that mean several of your requests are timing out.
Have you checked whether you’re actually getting meaningful data from your requests?
Ping360’s auto_* functionality is not yet meaningfully publicly available, so if you’re trying to make use of it then you’re likely just getting a bunch of timeouts.
Ping Viewer is able to make use of it if the device supports it, but it’s highly unlikely your Ping360 has a supporting firmware installed, because we haven’t yet provided a Ping Viewer release that allows flashing on a new firmware.
