I run BlueOS 1.4.7 stable on Rpi5 and use Pixhawk 6c mini. When I connect the USB-C port of 6Cmini to a Rpi5 USB port, BlueOS immediatly detect the Autopilot and list all parameter etc. When I connect the 6Cmini telem1 port to Rpi5 GPIO pin 14(tx), 15(rx) and ground, BlueOS do not detect the autopilot. I double check the tx-rx. I also swap them just in case. No luck.
I feel I need to enable those pin at the Raspberry or BlueOS level to have acces to UART? I don’t know how.
I configured telem1 port in QGC for mavlink protocol, 57600baud. I am mostly confident this part is correct.
BlueOS does not yet support non-USB serial connections to flight controller boards. There is a longstanding issue about it, which you can check for context and to see attempts to fix the problem so far.
A pull request would be welcomed if you’re willing to fix the issue
Hi Eliot, now that I followed the link you provide I realise it was not the thread on BR forum (the one I read already) but a link to the issu on Github. I will follow it now. Thank you.
