Hello everyone,
We are operating a BlueROV2 equipped with a Water Linked DVL A50. The flight controller is a Navigator running ArduSub.
We are experiencing a gradual difference between the ROV’s actual heading and its estimated heading. As the heading error increases, the position track recorded using the DVL also appears to rotate.
The main symptoms are:
The estimated heading gradually changes even when the ROV is pointing in a constant direction.
A heading offset remains after turning the vehicle.
The complete DVL position track rotates as the heading error increases.
The heading error may change depending on thruster output or vehicle operating conditions.
We are considering the following possible causes:
Magnetic interference from the T200 thrusters, ESCs, or power wiring
Accuracy or installation-environment limitations of the Navigator magnetometer
Time-dependent drift caused by IMU gyro bias
The way ArduSub’s EKF fuses magnetometer, gyro, and DVL data
The handling of heading and coordinate data between the Water Linked DVL A50 and ArduSub
We would appreciate advice on the following questions:
In this configuration, is the heading used to calculate the DVL position track derived from the Navigator magnetometer and ArduSub EKF, or does the DVL A50 perform any independent heading estimation?
What settings or sensor values should we examine to determine whether the heading drift originates from the Navigator magnetometer, gyro, EKF, or DVL integration?
Can ArduSub’s EKF settings be adjusted to improve the fusion or weighting of magnetometer and gyro data?
Can DVL velocity data be used to correct or constrain heading drift from the gyro or magnetometer?
If we replace the magnetometer or install an external one, are there any products with proven use on the BlueROV2?
When using an external magnetometer, what separation distance from the thrusters, ESCs, and power wiring is generally recommended?
For this problem, would it be more appropriate to improve the compass installation or to modify the EKF and DVL integration logic?
Would a FOG (fiber-optic gyroscope) or higher-grade AHRS be an effective way to reduce reliance on the magnetic compass?
Are there any specific FOG, AHRS, or heading-sensor products that have been successfully used with the BlueROV2 or ArduSub?
Can a FOG or external AHRS be connected directly to the Navigator/ArduSub system, or would we need a separate companion computer running a custom EKF to fuse the DVL, FOG, and other sensor data?
Our goal is to determine whether the most practical solution is to replace or relocate the magnetometer, improve the EKF logic, or introduce a FOG-based heading sensor.
Thank you in advance for your advice.
