In specs for new Fathom Tether it lists a minimum bend diameter of 8 inches and I am wondering how critical this is?
With our std CAT5 tether we have been storing/deploying it on/from a rectangular frame made of 1" PVC and it has held up. If we wind the new tether on this frame I do the 8" bend diameter will not be enforced. How have you been / how do you recommend hand storing/deploying the new tether. Does the strength member and construction of the new tether help prevent bending the tether too tightly?
Also we were thinking of building some sort of spool for the tether - do you think we could go tighter than the 8 inch diameter if there is low tension and a limited no. of cycles?
Please let me know what you know about the ruggedness and use of the new thether.
Thanks and best regards,
Paul
