Fathom spool assembly query- large version
Hi folks, quick (simple!) question- we have just purchased the heavy configuration BlueROV with 300m cable & spool, large version of the spool. I’m just wanted to check with the Fathom Spool assembly should we use the outer holes in the blue stiffening ring for the spool standoffs, or the inner ones (to give more space for the 300m length cable once it’s wound up)?
Many thanks!
Hi @AClements
Welcome to the forums!
Your question is answered in the documentation.
It sounds like you made the right assumption about using the inner holes!
