I’m having a hard time figuring out what the tray with terminal blocks and hardware provide that the tray doesn’t. I’m sorry if i seem to be acting immature but i really need a detailed description illustrating the difference between the two.
@Faraznisar Can you please link to the two products you are asking about? I’m not sure what you are looking at.
Thanks for the concern and here it is https://bluerobotics.com/store/watertight-enclosures/4-series/wte4-etray-r1/
I still do not understand the original question. It is an electronics tray with hardware that allows you to mount the tray inside of a 4" enclosure.
I’m sorry, I understand now. The tray only includes the tray and hardware to mount it in the 4" enclosure. The tray + the terminal blocks includes the same plus terminal blocks for power distribution and euro terminals for connecting 6 ESCs to 6 thrusters. The terminal block option adds the things circled in red here:
That’s it. Thanks for helping me out.
hey can anyone share 4 inch electronic tray single parts Actully i cant open assembly i need seprate parts CAED MODELS
Hi @Smalkhed,
- Which parts do you need models of?
- Is it just the panels, or also the standoffs, terminal blocks, and/or electronics?
- Do you have a preferred file format, that you’re able to open?
- If this is for a new/custom build, have you considered our RAILS system instead?
- The RAILS product page already includes individual models for the different components
hello
- yeah i need it for electronics which i will fit in hull
i need it in sldprt format normal which i can open in solidworks
That does not answer my question.
SolidWorks should be able to open most 3D model formats, including both individual parts and assemblies. What isn’t working when you try to import our publicly available models? They are already provided as .SLDPRT files (along with a few other common formats).
