Right, so you’re after something you can control/record from over a tether, like the following?
- our Low-Light HD USB camera
- this AI-filtered one
- this 4K + stereo one
- this 4k25 / 1080p60 one
- any IP camera
Note that the first three require a computer board (e.g. Raspberry Pi) with them for interfacing control and recording, but that would also be required anyway if you’re also controlling lights, which is generally the case with drop cams.
If you’re able to describe more of what you actually want/are looking for then we can likely help you determine the information you’re after, or at least where to look for it ![]()
