What is the difference between the Blue Robotics I2C level converter and others available? The only thing I can see is that the output has the option for 5V as well as 3.3V, both are bidirectional.
I am using a Bar02 pressure sensor and it works great from the Blue Robotics one, but when I connect it to a 3rd party one, it won’t work. The only difference is the 3rd party one is set to 3.3v but the specs say that is OK. What 3rd party ones (with more channels) will work, I would like to have additional sensors use the same converter.
