Hi, I am trying to program the Bar30 and Celsius to take measurements at
the same time on the Arduino Mega. I was wondering how to combine the
example library, TSYS01.h, and MS5837.h. I want the measurements to be
run at the same time or at least on the same code file. The error state: Compilation error: 'class TSYS01' has no member named 'begin'.
I tried combining code like this:
#include <Wire.h>
#include <MS5837.h>
#include <TSYS01.h>
MS5837 sensor;
TSYS01 tsys01;
void setup() {
Wire.begin();
// Initialize the MS5837 sensor
if (!sensor.init()) {
Serial.println("MS5837 sensor not found!");
while (1);
sensor.setModel(MS5837::MS5837_30BA);
sensor.setFluidDensity(1029);
// Initialize the TSYS01 sensor
if (!tsys01.begin()) {
Serial.println("TSYS01 sensor not found!");
while (1);
Serial.begin(9600);
void loop() {
// Read and display MS5837 sensor data
sensor.read();
Serial.print("MS5837 Pressure: ");
Serial.print(sensor.pressure());
Serial.print(" mbar, Temperature: ");
Serial.print(sensor.temperature());
Serial.println(" degC");
// Read and display TSYS01 sensor data
float temperature = tsys01.readTemperature();
Serial.print("TSYS01 Temperature: ");
Serial.print(temperature);
delay(1000);
The error is telling you that your tsys01 object has no begin method. If you look at our library example you’ll see that the correct method to perform the sensor initialisation is tsys01.init(), not tsys01.begin().
In that case I’d recommend taking the measurement readings as close together as possible, then printing the output(s) afterwards - e.g. change your structure to
void loop() {
... // Read MS5837 sensor data
... // Read TSYS01 sensor data
... // Print both sets of sensor data
... // delay to avoid too much output
In the 1.0.0 version of our BlueRobotics_TSYS01_Arduino library the TSYS01::init() function has no return value, so your if (!tsys01.init()) {...} block doesn’t make sense - it should instead just be an unchecked tsys01.init(); call.
Thanks for bringing this up though - we apparently recently made that function return a boolean but didn’t update the library version, so we’re doing that now. You should be able to update to version 1.0.1 in the next day or so, after which your current code should no longer be running into that compilation error
Sorry about that, we updated the version number but forgot to make a new tag, so the Arduino package manager didn’t know to look for it. It’s fixed now, and I’ve confirmed that the 1.0.1 version shows up
In your own program you can print the data however you want
As an example (modifying your posted code), you might want to do something like
... // includes
void setup() {
... // sensor initialisation
Serial.begin(9600)
// Print the header for a CSV file
Serial.println("MS5837 Pressure [mbar],MS5837 Temperature [degC],TSYS01 Temperature [degC]");
void loop() {
// Read the data and print it comma-separated
sensor.read()
Serial.print(",");
Serial.print(",");
Serial.println(tsys01.readTemperature());
delay(1000);
in which case you can copy the output into a CSV file and open it in your spreadsheet or processing application of choice
