Cannot Find the Leak
After installing a temperature sensor and repairing an issue of the laser, the software detected a leak. It was only a drop inside the main cabin. The sensor is firmly bonded with the rear plate. Underwater the left laser radiated the ray in a completely wrong direction fanned out.
I cleaned all sealing rings and lubricated them with new silicon grease.
During a new deployment, a leak has been detected in a depth of 2m. Inside the main cabin in the front, I saw ca. 20ml water. At home, I tried to find the leak with a leak detection spray, without success.
How can I locate the leak? I want to avoid to put the ROV underwater with overpressure. I suspect that the leak is in the laser. Can there be a connection via the laser to the main cabin? A connection is definitely between battery chamber and main cabin.
Hi @dr_stony -
I’m not sure what you’re referring to by the “laser” - but it is indeed possible for gas and liquids to travel between housings along cables. If you’re using any potted penetrators, these are a frequent source of leak failures as well.
This video shows how you can pressurize an enclosure to find leaks with super soapy water, it may help!
If you have blank penetrators, change them out with the normal penetrators one by one and do a vacuum test after each one. A little time consuming, but that’s how i manage to find some tricky leaks.
I’ve had one in a thruster cable twice, so it does not have to be in the penetrator itself.
I made this electric vacuum pump to test it much faster.
I found the leak it. There it is, at the front dome, under the edge, that you can not see it. I never saw something like this in plexi glas before.
Sprung in der Kuppel2
Nice find! I have had domes crack like that when subjected to impact loading… glad you found the problem!
I had a tough leak to find. Turned out to be a leak caused by a cable tie breaking the wire sheathing.
I am very sure, that there was no impact. May be, the dome has been exposed to tension. It was exactly at the position of one of the tight screws. I could be caused by a material failure.
The vacuum test was ok. But -0.1 atmosphere is different to 5 m depth. Therefore, I do not wonder that I did not find the leak outside the water.
I’ve had a lot of those failures.
I once cracked two domes while trying to replace them.
The edge of the perspex dome touches against the machine screws, I was trying to be as careful as possible, tightening them loosely and alternating which screw I was tightening.
I would recommend having a lot of spare domes for when you do have to replace them.
If anybody has advice on how to replace them safely it would be greatly appreciated.
