Can you provide me with video camera options for the ROV (that goes inside the electronic enclosure) so I can replace the one that comes with it, since I want better resolution.
I had the idea of disassembling an IP security camera and using the 6 wires left over from the umbilical cord to use them on the IP camera, so that it goes inside the electronic enclosure, more specifically, inside the dome. And to view the video, I attach these surface cables with Valum connectors to a DVR to see the image in real time. Is this possible? Will I get the video signal correctly? Will there be noise in the image or a delay? Thank you. I AWAIT YOUR ANSWERS
Hi @Rov1,
There are some previously discussed options and considerations summarised here. We are also actively working on a couple of different camera alternative projects, but I can’t provide information on them until they’re released.
This could potentially work, but you’re then limited to a tether length with a suboptimal cable for ethernet transfer. We would typically recommend using an ethernet switch of some kind instead.
THANKS YOU MY FRIEND
