Hi, I’m looking for intrinsic camera parameters, focal lengths and optical centers for the default BlueROV2 camera as needed by openCV applications. More info on these parameters : OpenCV: Camera Calibration
Are these parameter values already available with anyone? I guess these values will differ from air operation to underwater operation.
Looking for the same kind of information here like the camera K matrix and distortion coefs Are there any news ?
I’m starting a photogrammetry project and trying to figure out camera calibration.
Does the K matrix change wether you’re using it in the air or water ?
Is it unique to every camera or do the same model have the same parameters ?
Thank you
If it’s helpful, there’s an example of some parameters later in that thread that may be useful as a starting point, but if you want calibrated cameras then you’ll need to run a calibration on the exact camera you’re using, while it’s in the intended operating environment.
