I have a BlueROV2 Heavy R3 that I would like to upgrade from the existing Raspberry Pi 3 / Pixhawk setup to:
Raspberry Pi 4 / Pi 5?
Navigator Flight Controller
BlueOS
Before ordering the hardware, I would like to make sure that I have all the components required for the conversion.
The ROV also has the following equipment installed:
Newton Gripper
Ping1D sonar
Standard camera tilt
Standard BlueROV2 lights
My main question is:
Which additional components are required to upgrade a BlueROV2 Heavy R3, besides the Raspberry Pi 4 and Navigator Flight Controller?
In particular, I would like to know whether I need any additional components or adapters, for example:
JST-GH / DF13 adapter cables
power or power-sense cables
sensor cables or adapters
special mounting hardware
different connectors
cables or adapters for the Newton Gripper
cables or adapters for the Ping1D
Can the existing R3 components, especially the power sense module, depth sensor, camera, lights, Newton Gripper and Ping1D, be reused directly with the Navigator / Raspberry Pi 4?
Or are there any R3-specific cables or adapters that I should definitely order at the same time?
I am aware of the Navigator Retrofit Guide, but I would like to make sure that I can order everything needed for a BlueROV2 Heavy R3 in one shipment and avoid discovering during the upgrade that I am missing a specific cable or adapter.
If there are any other recommended hardware changes when performing this upgrade, I would also appreciate any advice.
