I would like to ask about the update rate for the sensors of the BlueESC
Hi Ahmed,
The current, voltage, and temperature update at about 1 Hz. The RPM measurement keeps track of pulses sent to the motor so it is updated very quickly, but is less accurate if read very fast.
Best,
Rusty
Hi Rusty,
I have bought blue depth sensor(rated for 30bar pressure ) but it is not working properly when I am keeping it till some 10cm depth in water.
I have followed every instruction and using it with Arduino
not working means it is not showing exact reading, serial monitor stops communicating.
Pls give me possible solution
Hi Chetan,
Can you tell me more about the problem? Does it work initially? How long before it stops communicating? Does it work again if you reopen the serial monitor?
Also, are you using a logic level converter to convert the I2C signals from 5V (Arduino) to 3.3V (sensor)?
