Benefits upgrading BR2 with Navigator and New Raspberry
It’s not an essential upgrade if you’re already happy with your existing flight controller, but it may still be of interest - there’s an overview of both in the Technical Reference if you want to compare. Functionally speaking the Navigator
  • is a bit more tailored to ArduSub use-cases
    • e.g. there are leak probe connectors built in
  • has a couple of extra PWM outputs
  • has more usable connectors
  • has more potential for expandability
    • we’re planning to make libraries available for accessing the sensors and connectors, so that they’re accessible from user code outside the autopilot firmware, but that hasn’t been done yet
  • does not yet support relay outputs → relay support added in ArduSub 4.1.1
    • I believe there’s currently a working branch that’s being tested - it should hopefully be merged in to the main ArduSub reasonably soon
  • is more robust when updating firmware (because it’s just files on the Raspberry Pi)
  • has easier to access log files
If you do decide to upgrade,
